GT
Title, DataSource and shortcut
Joined: 3/20/2026(UTC) Posts: 2  Location: Gothenburg
I have a title that is linked to a Excel Spreadsheet as a Data Source and I have run into problems.
I have done these types of shortcuts before on a different computer but now it will not let me enter the spreadsheet value in the shortcut.
The box with the following text will not let me change it
--- "Name of the Data Source and Table Name (optional) eg 'Excel/CSV,Sheet1'" ---
Does anyone know what I am doing wrong? Same problem for all different DataSource shortcut options
I'm on vMix Pro - 29.0.0.46 and using Microsoft Excel with a Stream Deck +XL
Originally Posted by: blidkvist  I have a title that is linked to a Excel Spreadsheet as a Data Source and I have run into problems.
I'm on vMix Pro - 29.0.0.46 and using Microsoft Excel with a Stream Deck +XL this box is just to display some help You have to edit the Value box
Originally Posted by: doggy  Originally Posted by: blidkvist  I have a title that is linked to a Excel Spreadsheet as a Data Source and I have run into problems.
Ah, thank you! This made me realize my problem, I was trying use a vMix button on the rotate dial on the StreamDeck +XL and that button did not reveal the value box. Made me also remember that I made work arounds on the other computer. Not to set the dial as a vMix shortcut but make it a regular Stream Deck Hot Key.
Thanks: 75 times Was thanked: 7 time(s) in 7 post(s)
Hello everyone, I come to you with a request, namely: how can I put the name and the artist over a playlist of audio files? Thank you very much for your help
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
 1 user thanked Peter1000 for this useful post.
GT
