DDOtoo
#1 Posted : Sunday, January 5, 2014 4:31:24 PM(UTC)
DDOtoo
I have an old sony dv-cam, DSR 370p, connected to the Decklink quad and all I get is a black screen. When I connect through Svideo to USB port it shows. What could be the reason. I have set the resolution to 1080i as my other JVC hd pro cams.
Any guidance please.
asvtv
#2 Posted : Sunday, January 5, 2014 7:34:37 PM(UTC)
asvtv
Is your sony cam output in SDI ?
DDOtoo
#3 Posted : Sunday, January 5, 2014 7:51:30 PM(UTC)
DDOtoo
I have been researching on it and I have learnt that the Decklink only receives digital whiles the sony is analogue so I guess I need an SDI convertor to do the trick, fingers crossed. Blackmagic converters may do it for me.
Thanks.
asvtv
#4 Posted : Monday, January 6, 2014 7:06:57 PM(UTC)
asvtv
Yes you need a analog to SDI converter (Blackmagic converters are really great, we owned 5 of them and we never had a problem with them)
thanks 1 user thanked asvtv for this useful post.
DDOtoo on 1/6/2014(UTC)
