Hardware Compatibility
Sony Dv Cam not showing in vmix through Decklink quad
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
I have an old sony dv-cam, DSR 370p, connected to the Decklink quad and all I get is a black screen. When I connect through Svideo to USB port it shows. What could be the reason. I have set the resolution to 1080i as my other JVC hd pro cams.
Any guidance please.
Thanks: 24 times Was thanked: 10 time(s) in 8 post(s)
Is your sony cam output in SDI ?
asvtv wrote:Is your sony cam output in SDI ? I have been researching on it and I have learnt that the Decklink only receives digital whiles the sony is analogue so I guess I need an SDI convertor to do the trick, fingers crossed. Blackmagic converters may do it for me. Thanks.
Yes you need a analog to SDI converter (Blackmagic converters are really great, we owned 5 of them and we never had a problem with them)
 1 user thanked asvtv for this useful post.
