niemi
#1 Posted : Saturday, September 22, 2018 3:04:46 PM(UTC)
niemi
Was thanked: 19 time(s) in 16 post(s)
Do you know of any capture cards supporting dual or quad channel 4K?
Have a great weekend.
TechnicalMonkey
#2 Posted : Saturday, September 29, 2018 1:22:48 AM(UTC)
TechnicalMonkey
I can think of one that natively supports it, but in displayport only. Datapath VisionSC-DP2 captures 2xDisplayPort 1.2 connections.
There is an 8K capture card from Blackmagic Design that uses 4x12G-SDI connections, but I think that the signals need to be synced by an external clock. Some people claim that if the 4K signals are synced that you might be able to have 4x4K signals, but that sounds like a real pain if it is true.
zenvideo
#3 Posted : Saturday, September 29, 2018 3:55:28 AM(UTC)
zenvideo
Magewell was showing a dual channel version of the Pro Capture HDMI 4K Plus at IBC, which may be available before the end of this year.
RadekOlszakPl
#4 Posted : Sunday, October 28, 2018 9:05:05 AM(UTC)
RadekOlszakPl
I was reading about DeckLink 8K Pro and i found that it CAN INPUT only one stream.
I dont know what for are the rest of sdi inputs. Maybe for audio etc.
zenvideo
#5 Posted : Sunday, October 28, 2018 6:24:24 PM(UTC)
zenvideo
I believe this is now shipping - Pro Capture Dual HDMI 4K Plus
Vuurmannetje
#6 Posted : Sunday, October 28, 2018 11:01:50 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
Without any merge/unmerge tricks or getting into actual programming, the 8K supports either 1 8K i/o switchable, or a simultaneous 4K input+output on single/dual link.
niemi
#7 Posted : Tuesday, November 6, 2018 10:09:53 PM(UTC)
niemi
Appears to be a quad channel 4K option:
YUAN SC560N4 4-Channel PCIe x4 HDMI 4K Capture Card
https://www.yuan.com.tw/...ture/4k/sc560n4_hdmi.htm
Guest (9)
