Hardware Compatibility
Any capture cards supporting dual or quad channel 4K?
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
Do you know of any capture cards supporting dual or quad channel 4K?
Have a great weekend.
I can think of one that natively supports it, but in displayport only. Datapath VisionSC-DP2 captures 2xDisplayPort 1.2 connections.
There is an 8K capture card from Blackmagic Design that uses 4x12G-SDI connections, but I think that the signals need to be synced by an external clock. Some people claim that if the 4K signals are synced that you might be able to have 4x4K signals, but that sounds like a real pain if it is true.
Magewell was showing a dual channel version of the Pro Capture HDMI 4K Plus at IBC, which may be available before the end of this year.
Originally Posted by: TechnicalMonkey  I can think of one that natively supports it, but in displayport only. Datapath VisionSC-DP2 captures 2xDisplayPort 1.2 connections.
There is an 8K capture card from Blackmagic Design that uses 4x12G-SDI connections, but I think that the signals need to be synced by an external clock. Some people claim that if the 4K signals are synced that you might be able to have 4x4K signals, but that sounds like a real pain if it is true. I was reading about DeckLink 8K Pro and i found that it CAN INPUT only one stream. I dont know what for are the rest of sdi inputs. Maybe for audio etc.
Originally Posted by: zenvideo  Magewell was showing a dual channel version of the Pro Capture HDMI 4K Plus at IBC, which may be available before the end of this year. I believe this is now shipping - Pro Capture Dual HDMI 4K Plus
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Originally Posted by: RadekOlszakPl  Originally Posted by: TechnicalMonkey  I can think of one that natively supports it, but in displayport only. Datapath VisionSC-DP2 captures 2xDisplayPort 1.2 connections.
There is an 8K capture card from Blackmagic Design that uses 4x12G-SDI connections, but I think that the signals need to be synced by an external clock. Some people claim that if the 4K signals are synced that you might be able to have 4x4K signals, but that sounds like a real pain if it is true. I was reading about DeckLink 8K Pro and i found that it CAN INPUT only one stream. I dont know what for are the rest of sdi inputs. Maybe for audio etc. Without any merge/unmerge tricks or getting into actual programming, the 8K supports either 1 8K i/o switchable, or a simultaneous 4K input+output on single/dual link.
