TVIason
#1 Posted : Thursday, November 21, 2013 12:25:28 PM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Martin,
Correct me if I'm right, but when I want to use an ipcam I can't directly input the video feed. Is there An possebillity for an direct http feed?
I know there is one in vidblaster and in wirecast, but I like vmix wat more.
Thanks a lot
wscawebcast
#2 Posted : Thursday, January 9, 2014 3:32:21 PM(UTC)
wscawebcast
I didn't see a response to this, but add an input of type STREAM, then specify the IP address for the camera. I'm using it successfully with 10 cameras and RTSP streams.
thanks 1 user thanked wscawebcast for this useful post.
TVIason on 1/9/2014(UTC)
wwdv
#3 Posted : Friday, January 10, 2014 2:21:20 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
Do you have a delay when using streaming?
wscawebcast
#4 Posted : Saturday, January 11, 2014 8:57:40 PM(UTC)
wscawebcast
Not a significant delay. Accessed directly (HTTP) through a browser, there is no delay for the cameras. Via RTSP to vMix, there's very little delay (milliseconds). Of course, when I'm broadcasting to Ustream, there's a 5-30 second delay depending on the viewing device.
wwdv
#5 Posted : Saturday, January 18, 2014 1:02:48 PM(UTC)
wwdv
About streaming delay:
vMix help:
The network buffer in milliseconds can be configured to reduce jitter when receiving high latency network streams.
For local network streams, this should be set between 0 and 500 milliseconds or 1000 to 5000 milliseconds for Internet streams.
Low Latency Mode
Local streaming devices such as the Teradek cube support a delay of less than 5 frames in Low Latency Mode.
To use this mode, set the Buffer to 0 and tick the Low Latency Mode checkbox.
See also this ip camera thread
My Sony SNC-ZP550 IP camera has 1second delay with rtsp stream.
THPI
#6 Posted : Monday, January 27, 2014 1:26:55 PM(UTC)
THPI
Who makes cameras that support RTMP in the US?
wscawebcast
#7 Posted : Tuesday, January 28, 2014 2:24:56 PM(UTC)
wscawebcast
I'm using Axis P3346 cameras. Axis.com. They have a wide range of IP cameras that should work as Stream inputs to vMix. The P3346 offers a number of output stream formats, I'm using h.264.
Similar Topics
RTSP IP Camera Input Image loss (General Discussion)
Belarus robocox 2/20/2021 1:22:46 AM(UTC)
