fenki86
#1 Posted : Sunday, November 17, 2013 4:57:49 PM(UTC)
fenki86
would be great to put multiple shortcuts on one particular key.
in my particular case it would be amazing for the Game clock and penalty clock. I'd love to put the "Start Countdown" and "Pause Countdown" for each clock on one special key.
The penalty clock and the game clock could then be started/paused by pressing just one button.
Other possibilities to solve this particular "problem" are appreciated.
Greetings from Austria
Fenki
#2 Posted : Sunday, November 17, 2013 5:09:04 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Hi Fenki,
You can do this by first creating the two shortcuts separately (to say the A and B keys)
Then go to the A key shortcut options and under the Advanced tab set it to trigger the B key as well.
fenki86 on 11/17/2013(UTC)
fenki86
#3 Posted : Sunday, November 17, 2013 6:22:57 PM(UTC)
fenki86
Absolutely perfect!
Thanks a lot for the quick reply.
Very much appreciated.
Great service on the whole product. Thank you Martin!
Similar Topics
Multiple Shortcuts in one press (Feature Requests)
by vjmandala 11/27/2024 8:59:38 AM(UTC)
Add the Capability to Set Multiple Shortcuts to Either Local or Global (Feature Requests)
by avsoundguy 2/14/2023 10:27:34 AM(UTC)
Add the ability to Select and Reassign multiple shortcuts (Feature Requests)
by avsoundguy 3/18/2021 8:58:59 AM(UTC)
Warning When Multiple Shortcuts Assigned to the Same Button (Feature Requests)
by greggibson 9/11/2020 2:09:48 AM(UTC)
