Feature Requests
Add the ability to Select and Reassign multiple shortcuts
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Add the ability to Select and Reassign multiple shortcuts to a different input It would come in handy when a client has moved a i.e. scoreboard from the original input and the shortcuts need be reassigned quickly because the game is about to start.
 1 user thanked avsoundguy for this useful post.
Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
One of these methods:
1. Assign the shortcuts to the Input's Name and not its number. Then simply rename the old and new Inputs.
2. Use SetDynamicValue
3. (depending on what "multiple shortcuts" means and your use case). Put shortcuts in a script and apply with triggers
Joined: 6/28/2020(UTC) Posts: 11  Location: Scottsdale
Feature Requests
