I am trying to find the best way to connect my Sony HVR-HD1000U to my Dell laptop. I have successfully connected it via a Firewire cable (Sony calls them iLink cables)to my laptop through a Firewire Express card. It seems to work - but we keep losing audio or it seems a little glitchy. Should I buy some kind of capture device? The BM Intensity says its not compatible with Dell?? Any ideas? Dell System Specs
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
etbuh wrote:I am trying to find the best way to connect my Sony HVR-HD1000U to my Dell laptop. I have successfully connected it via a Firewire cable (Sony calls them iLink cables)to my laptop through a Firewire Express card. It seems to work - but we keep losing audio or it seems a little glitchy. Should I buy some kind of capture device? The BM Intensity says its not compatible with Dell??
Any ideas? Write your Dell's specification, because the only thing we know is the brand. We also know it has expresscard. I can tell You that I sucessfully use my Dell Precision laptop with expresscard HDMI grabber manufactured by Yuan http://www.yuan.com.tw/e...oducts1_1_spec_sc500.htm (the one on the right). You can find this card under different brandname (for example swedish brand JMC in Europe).
 1 user thanked r@wisla for this useful post.
I posted the specs. Is firewire okay to use in the first place?
etbuh wrote:Is firewire okay to use in the first place? No. Using firewire results in large video delay. Use HDMI capture cards.
