etbuh
#1 Posted : Saturday, November 16, 2013 11:10:25 PM(UTC)
etbuh
I am trying to find the best way to connect my Sony HVR-HD1000U to my Dell laptop. I have successfully connected it via a Firewire cable (Sony calls them iLink cables)to my laptop through a Firewire Express card. It seems to work - but we keep losing audio or it seems a little glitchy. Should I buy some kind of capture device? The BM Intensity says its not compatible with Dell??
Any ideas?
Dell System Specs
ask
#2 Posted : Sunday, November 17, 2013 1:55:10 AM(UTC)
ask
If you can use a ExpressCard and your camera has HDMI have a look at the Timeleak HD82E....http://www.timeleak.com.cn/en/article/view.php?ps_db=prod&pnid=2&ps_aid=19
Otherwise check out the Magewell Capture devices. http://www.magewell.com/hardware?lang=en
r@wisla
#3 Posted : Sunday, November 17, 2013 5:06:07 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Any ideas?
Write your Dell's specification, because the only thing we know is the brand. We also know it has expresscard.
I can tell You that I sucessfully use my Dell Precision laptop with expresscard HDMI grabber manufactured by Yuan
http://www.yuan.com.tw/e...oducts1_1_spec_sc500.htm (the one on the right). You can find this card under different brandname (for example swedish brand JMC in Europe).
thanks 1 user thanked r@wisla for this useful post.
etbuh on 11/17/2013(UTC)
etbuh
#4 Posted : Sunday, November 17, 2013 10:08:00 PM(UTC)
etbuh
I posted the specs. Is firewire okay to use in the first place?
r@wisla
#5 Posted : Monday, November 18, 2013 6:53:45 PM(UTC)
r@wisla
No. Using firewire results in large video delay.
Use HDMI capture cards.
