h2video.nl
#1 Posted : Friday, November 1, 2013 4:05:02 PM(UTC)
h2video.nl
hi martin,
would it be possible to set fixed directories for recordings and presets, preferably in settings. so they don't change to last dir used.
now when you want to save a preset you will be directed to the last used directory. that can be confusing and cumbersome when setting up a project.
stefan
cutter07
#2 Posted : Wednesday, November 6, 2013 11:12:26 AM(UTC)
cutter07
This would be very helpful.
#3 Posted : Wednesday, November 6, 2013 11:19:26 AM(UTC)
Was thanked: 4741 time(s) in 1627 post(s)
As a possible solution, in all open file dialogs under Windows 7 or higher there is a Favourites section in the left hand column.
Simply drag and drop any folders you regularly access in vMix in to Favourites.
h2video.nl
#4 Posted : Thursday, November 7, 2013 9:23:05 AM(UTC)
h2video.nl
yes i know.
but i use presets as a frequent tool to be able to switch recording session and with all settings prepared. it is a hassle to have to check the preset dir every time. so sometimes i save them in a different directory because this was last used.
if you set it to a fixed directory, i can save them quickly and i always know where they are for quick use.
stefan
doyousee.me
#5 Posted : Wednesday, November 13, 2013 5:00:38 AM(UTC)
doyousee.me
briliant idea
i'm always searching for my vmix files as well
M@ik
