Feature Requests
selectable directories for recordings and presets
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
hi martin,
would it be possible to set fixed directories for recordings and presets, preferably in settings. so they don't change to last dir used.
now when you want to save a preset you will be directed to the last used directory. that can be confusing and cumbersome when setting up a project.
stefan
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
Quote: to set fixed directories for recordings and presets This would be very helpful.
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
As a possible solution, in all open file dialogs under Windows 7 or higher there is a Favourites section in the left hand column. Simply drag and drop any folders you regularly access in vMix in to Favourites.
yes i know.
but i use presets as a frequent tool to be able to switch recording session and with all settings prepared. it is a hassle to have to check the preset dir every time. so sometimes i save them in a different directory because this was last used.
if you set it to a fixed directory, i can save them quickly and i always know where they are for quick use.
stefan
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
briliant idea i'm always searching for my vmix files as well
M@ik
Feature Requests
