aircooled76@gmail.com
#1 Posted : Saturday, October 26, 2013 6:56:18 AM(UTC)
Hi Guys,
I have an error when using a keyboard shortcut to save a Video Delay. When I click the save button on the delay it saves with no problem... but using the shortcut key I get the following error:
11.0.0.41 - VideoDelay_SaveCompleted - 25/10/2013 11:43:50
vMix.VMIXException: Error Loading Input. ---> System.IO.FileNotFoundException: File Not Found: e:\\delay - decklink video capture - 25 October 2013 - 11-43-40 AM.avi
at ej.u(String a)
at fl.b(String a)
at fi.a._Lambda$__147()
--- End of inner exception stack trace ---
My shortcut key settings are:
Key: C
Function: SaveVideoDelay
Duration: 1000
Input: Delay - Decklink Video Capture 4
Any suggestions as to what I am doing wrong?
#2 Posted : Saturday, October 26, 2013 7:51:52 AM(UTC)
Could you try setting a higher duration on the shortcut, say 10000 and see what happens?
Also, what codec are you using when creating the video delay?
#3 Posted : Saturday, October 26, 2013 10:19:10 PM(UTC)
Hi Martin,
Thanks for the quick reply... Ill test it... using BlackMagic MJPEG..
Changing the time to 10000 fixed the problem... cheers!
