Video Delay error when saving
Joined: 8/15/2013(UTC) Posts: 108   Location: Could be Australia could be Europe/UK! Thanks: 2 times Was thanked: 9 time(s) in 9 post(s)
Hi Guys, I have an error when using a keyboard shortcut to save a Video Delay. When I click the save button on the delay it saves with no problem... but using the shortcut key I get the following error: Quote:======================================== 11.0.0.41 - VideoDelay_SaveCompleted - 25/10/2013 11:43:50 ======================================== vMix.VMIXException: Error Loading Input. ---> System.IO.FileNotFoundException: File Not Found: e:\\delay - decklink video capture - 25 October 2013 - 11-43-40 AM.avi at ej.u(String a) at fl.b(String a) at fi.a._Lambda$__147() --- End of inner exception stack trace ---
My shortcut key settings are: Key: C Function: SaveVideoDelay Duration: 1000 Input: Delay - Decklink Video Capture 4 Any suggestions as to what I am doing wrong?
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Could you try setting a higher duration on the shortcut, say 10000 and see what happens? Also, what codec are you using when creating the video delay?
Martin vMix
Hi Martin,
Thanks for the quick reply... Ill test it... using BlackMagic MJPEG..
Changing the time to 10000 fixed the problem... cheers!
