newlifeus
#1 Posted : Monday, March 26, 2018 9:26:52 AM(UTC)
newlifeus
Hi there,
We transmit our sermon to Youtube and Facebook at the same time. We have a profile that contains both. We were having a high CPU usage and we followed the instructions given here for better performance.
This is the setting we have for streaming:
I noticed that when locally recording only, there is no high CPU usage but when we start to transmit, our GPU goes to the roof.
We are concerned because the "Stream" button goes orange during all transmission and we don't know if we are also "forcing" the Graphic Card.
Do you guys have any knowledge to share or configs to suggest that could help us?
This is our computer configuration:
Our graphics card is:
NVIDIA GeForce GTX 660 Ti
Mike
#2 Posted : Monday, March 26, 2018 10:23:10 AM(UTC)
Was thanked: 4765 time(s) in 1636 post(s)
Hi Mike,
Try running GPU-Z which is a free utility that provides more details on what part of the GPU is being used.
https://www.techpowerup.com/gpuz/
Check under the sensors tab while streaming.
newlifeus
#3 Posted : Monday, March 26, 2018 10:30:34 AM(UTC)
newlifeus
Martin,
Here's the result:
I just noticed that we actually have two graphic cards (probably in SLI). Shouldn't that do the job smoothly ?
admin wrote:
Hi Mike,
#4 Posted : Monday, March 26, 2018 4:22:52 PM(UTC)
@ newlifeus
vMix does not take advantage of multiple GPUs in SLI, in fact, performance can degrade by up to 50%.
It has to do with the amount of data being transfered per second and not being able to load balance among multile cards:
https://forums.vmix.com/....aspx?g=posts&t=3251
mjgraves
#5 Posted : Tuesday, March 27, 2018 11:30:57 AM(UTC)
mjgraves
Try removing one of the graphics cards.
Also, try switching to 720p.
Sending 1080p to Facebook is pointless since they only present 720p anyway. Their scaling of the stream results in worse quality than just sending them 720p.
