Hi there, We transmit our sermon to Youtube and Facebook at the same time. We have a profile that contains both. We were having a high CPU usage and we followed the instructions given here for better performance. This is the setting we have for streaming:  I noticed that when locally recording only, there is no high CPU usage but when we start to transmit, our GPU goes to the roof.  We are concerned because the "Stream" button goes orange during all transmission and we don't know if we are also "forcing" the Graphic Card. Do you guys have any knowledge to share or configs to suggest that could help us? This is our computer configuration:  Our graphics card is: NVIDIA GeForce GTX 660 Ti Mike
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi Mike, Try running GPU-Z which is a free utility that provides more details on what part of the GPU is being used. https://www.techpowerup.com/gpuz/Check under the sensors tab while streaming. Regards, Martin vMix
Martin, Here's the result:  I just noticed that we actually have two graphic cards (probably in SLI). Shouldn't that do the job smoothly ? admin wrote:Hi Mike, Try running GPU-Z which is a free utility that provides more details on what part of the GPU is being used. https://www.techpowerup.com/gpuz/Check under the sensors tab while streaming. Regards, Martin vMix
@ newlifeus vMix does not take advantage of multiple GPUs in SLI, in fact, performance can degrade by up to 50%. It has to do with the amount of data being transfered per second and not being able to load balance among multile cards: https://forums.vmix.com/....aspx?g=posts&t=3251Ice
Try removing one of the graphics cards.
Also, try switching to 720p.
Sending 1080p to Facebook is pointless since they only present 720p anyway. Their scaling of the stream results in worse quality than just sending them 720p.
