jwacht
#1 Posted : Thursday, March 1, 2018 5:54:15 PM(UTC)
jwacht
We are using our new Magewell USB Capture SDI 4K Plus to bring in an SDI camera and replacing the audio via the 3.5 audio in connection – audio is coming from a Sennheiser wireless lav microphone receiver.
In vMix the audio is only coming in on only one channel – even though it is voice only (host of interview), would like it to come in on both channels the way other guests audio in vMix Call comes in – so we don’t have to crank up gain or volume to distortion level to match other audio.
Any way to do that in card or vMix? A switch to capture a mono signal, something that will span both channels, a dual mono setting or the like?
Thanks.
Peter B
#2 Posted : Thursday, March 1, 2018 6:28:35 PM(UTC)
Peter B
Yes of course, it's vMix!
Have a look at the channel matrix in audio / settings.
Sdi is a great way to truck audio around, you'll notice
a huge difference.
https://www.vmix.com/help20/
