Hardware Compatibility
Magwell SDI 4k+ card with audio -- way to get on both channels?
Joined: 9/19/2013(UTC) Posts: 2  Location: San Diego, US
We are using our new Magewell USB Capture SDI 4K Plus to bring in an SDI camera and replacing the audio via the 3.5 audio in connection – audio is coming from a Sennheiser wireless lav microphone receiver.
In vMix the audio is only coming in on only one channel – even though it is voice only (host of interview), would like it to come in on both channels the way other guests audio in vMix Call comes in – so we don’t have to crank up gain or volume to distortion level to match other audio.
Any way to do that in card or vMix? A switch to capture a mono signal, something that will span both channels, a dual mono setting or the like?
Thanks.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Yes of course, it's vMix! Have a look at the channel matrix in audio / settings. Sdi is a great way to truck audio around, you'll notice a huge difference. https://www.vmix.com/help20/
