Hello all. New to vMix, previously used WIrecast. Does it make a difference in using overlay or just layering a shot with multiview? In other words, if I want a logo to appear on my main shot, should I use the overlay or just build a 2nd shot of the main shot with the logo as a multiview? I know both get the job done, but not certain if there are pros/cons that I am unaware of.
Thanks much!
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
webbej wrote:Hello all. New to vMix, previously used WIrecast. Does it make a difference in using overlay or just layering a shot with multiview? In other words, if I want a logo to appear on my main shot, should I use the overlay or just build a 2nd shot of the main shot with the logo as a multiview? I know both get the job done, but not certain if there are pros/cons that I am unaware of.
Thanks much! I consider multiview to be more permanent. We use a bug for most shots except for commercials. And if you want to setup a trigger that will remove the bug when you remove the shot, that is fine, but otherwise I think it is easier to put it in the Multiview. I use the overlay for things I want to show over my normal shot. For example, I have one setup for PIP of our 2nd camera. Lower thirds. Credits sometimes. Anything I want to be able to bring up and down quickly.
 1 user thanked jvphobic for this useful post.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Harkening back to my time with hardware production switchers....
...I think of multi-view as the keyers on the mix/effects buses. That's where I build complex composites before they are seen.
The overlay are the downstream keyers, for items that are transient, coming and going independent of the underlying shot.
