webbej
#1 Posted : Wednesday, November 22, 2017 10:40:39 AM(UTC)
webbej
Hello all. New to vMix, previously used WIrecast. Does it make a difference in using overlay or just layering a shot with multiview? In other words, if I want a logo to appear on my main shot, should I use the overlay or just build a 2nd shot of the main shot with the logo as a multiview? I know both get the job done, but not certain if there are pros/cons that I am unaware of.
Thanks much!
jvphobic
#2 Posted : Wednesday, November 22, 2017 10:53:16 AM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
Thanks much!
I consider multiview to be more permanent. We use a bug for most shots except for commercials. And if you want to setup a trigger that will remove the bug when you remove the shot, that is fine, but otherwise I think it is easier to put it in the Multiview.
I use the overlay for things I want to show over my normal shot. For example, I have one setup for PIP of our 2nd camera. Lower thirds. Credits sometimes. Anything I want to be able to bring up and down quickly.
thanks 1 user thanked jvphobic for this useful post.
webbej on 11/22/2017(UTC)
mjgraves
#3 Posted : Wednesday, November 22, 2017 11:55:44 AM(UTC)
mjgraves
Harkening back to my time with hardware production switchers....
...I think of multi-view as the keyers on the mix/effects buses. That's where I build complex composites before they are seen.
The overlay are the downstream keyers, for items that are transient, coming and going independent of the underlying shot.
