migi915
#1 Posted : Thursday, November 9, 2017 3:03:00 PM(UTC)
migi915
What type of computer specs do you all have on your VMIX systems that can do 4 camera replay? I know that the website has reference systems, however, there are so many components and PC builds out there that can probably get the job done just like the reference systems on the vmix website. The xmix website example has the following example:
Graphics Card
NVIDIA GeForce GTX 1060
Samsung 850 Pro 1TB SSD
Intel Core i7 7700K 4.2GHz +
16GB (2x8GB) DDR4
Windows 10
However, a friend of mine was able to get vmix with 4 camera replay on a computer with the following specs:
Dell desktop
i7-5930k 3.5 gHz
500 GB SSD
32gb RAM
Nvidia GeForce GTX 980i
Windows 10
I want to see what everyone is running? What is the absolute minimum needed for 4 camera replay. Any info is appreciated!
SportsNetUSA.net
#2 Posted : Friday, November 10, 2017 2:04:15 PM(UTC)
SportsNetUSA.net
Minimum system requirements from vMix User Guide for 4 Camera Instant Replay
OS - Windows 7 or higher (64 bit only). Windows 8.1 or higher recommended
CPU - Quad Core 4.0 Ghz (Six Core 3.6 Ghz highly recommended)
RAM - 8GB
Graphics - NVIDIA 960 2GB
Storage - Dedicated SSD for Replay 500GB and higher. 1TB recommended.
Storage Connection - Internal SATA 3 and higher only.
migi915
#3 Posted : Wednesday, November 22, 2017 10:47:34 PM(UTC)
migi915
I just bought a used Alienware small form factor desktop on ebay.
X51 R2
It has an i7 - 3.6 GHz processor
16GB Ram
256 GB SSD
and a 1 TB 5200RPM drive.
NVIDIA GeForce GTX 760 Ti OEM
I installed the full trial version of VMIX pro 20
It is set up for 4 camera replay!
ALL FOR JUST $375!!!!!
Because it's a small form factor PC the expansion slots for capture devices is taken. However, it does have 6 usb 3.0 ports. So with 6 magewell SDI or HDMI capture dongles, 6 cameras can be used with VMIX and 4 of them routed to the replay recorder.
AGAIN FOR $375!!!!!
