Instant Replay
Replay system specs - minimum
Joined: 11/9/2017(UTC) Posts: 2 Location: El Paso, Texas
What type of computer specs do you all have on your VMIX systems that can do 4 camera replay? I know that the website has reference systems, however, there are so many components and PC builds out there that can probably get the job done just like the reference systems on the vmix website. The xmix website example has the following example:
Graphics Card
NVIDIA GeForce GTX 1060 Samsung 850 Pro 1TB SSD Intel Core i7 7700K 4.2GHz + 16GB (2x8GB) DDR4 Windows 10
However, a friend of mine was able to get vmix with 4 camera replay on a computer with the following specs:
Dell desktop i7-5930k 3.5 gHz 500 GB SSD 32gb RAM Nvidia GeForce GTX 980i Windows 10
I want to see what everyone is running? What is the absolute minimum needed for 4 camera replay. Any info is appreciated!
Minimum system requirements from vMix User Guide for 4 Camera Instant Replay
OS - Windows 7 or higher (64 bit only). Windows 8.1 or higher recommended CPU - Quad Core 4.0 Ghz (Six Core 3.6 Ghz highly recommended) RAM - 8GB Graphics - NVIDIA 960 2GB Storage - Dedicated SSD for Replay 500GB and higher. 1TB recommended. Storage Connection - Internal SATA 3 and higher only.
I just bought a used Alienware small form factor desktop on ebay. X51 R2 It has an i7 - 3.6 GHz processor 16GB Ram 256 GB SSD and a 1 TB 5200RPM drive. NVIDIA GeForce GTX 760 Ti OEM
I installed the full trial version of VMIX pro 20
It is set up for 4 camera replay!
ALL FOR JUST $375!!!!!
Because it's a small form factor PC the expansion slots for capture devices is taken. However, it does have 6 usb 3.0 ports. So with 6 magewell SDI or HDMI capture dongles, 6 cameras can be used with VMIX and 4 of them routed to the replay recorder.
AGAIN FOR $375!!!!!
Instant Replay
