wtmuradiotv
#1 Posted : Saturday, July 8, 2017 7:51:11 PM(UTC)
wtmuradiotv
Instead of a side to side scroll .Can we get a up and down scroller also is this simple enough to come up with
thanks 1 user thanked wtmuradiotv for this useful post.
ghayden6 on 4/11/2018(UTC)
jet
#2 Posted : Monday, July 10, 2017 10:20:54 AM(UTC)
jet
Was thanked: 25 time(s) in 23 post(s)
+1
#3 Posted : Monday, July 10, 2017 10:45:06 AM(UTC)
mjgraves
#4 Posted : Monday, July 10, 2017 2:06:58 PM(UTC)
mjgraves
I worked for a CG company for 17 years. The proper terminology is:
Crawl - a text display that moves left/right. For example, a headline crawl on a news channel.
Roll - a text display the moves up/down. For example, the end credits of a movie.
To do both of these things well is a non-trivial matter. You may be well advised to consider an external CG application (Lyric, CasparCG, etc.)
There may be considerable advantage to having the CG generated on a different computer, using NDI to send it to the vMix system. This is most especially true if you want the text display to be updated remotely.
In the case of credit rolls, the text to be presented may well be known in advance. In that case, you can pre-render the roll using After Effects (or similar.) vMix can play the resulting file.
Similar Topics
able to scroll with middle mouse roller when selecting NDI source (Feature Requests)
by Grappa 7/18/2025 9:17:34 PM(UTC)
Only long text scroll lower thirds (GT)
by NSCPro 12/8/2023 6:59:26 AM(UTC)
Continuous Scroll On Ticker (GT)
by Widget 2/15/2023 4:54:21 AM(UTC)
Scroll Wheel increments Integer boxes (Feature Requests)
by tcconway 12/18/2022 1:52:42 AM(UTC)
GT Text Scroll - Row Limit (GT)
by tomGix 1/16/2021 9:05:44 AM(UTC)
Shortcut to scroll through Replay tags (Feature Requests)
by TFMG 12/11/2019 6:34:10 PM(UTC)
Scroll and maximize input (General Discussion)
by buzzbuzz 12/31/2017 7:14:32 PM(UTC)
Scroll ticker limitations (General Discussion)
by SpelingMistakes 3/24/2016 12:46:50 PM(UTC)
Modify Ticker to Scroll Left to Right for Arabic (Feature Requests)
Belarus sinc747 1/22/2016 1:46:08 PM(UTC)
Ability to Visually Scroll Through a List? (Feature Requests)
by rjmurdock 6/13/2015 10:04:20 AM(UTC)
Ticker Scroll is choppy??? (General Discussion)
by IceStream 5/27/2015 3:55:07 PM(UTC)
Ticker text scroll area. (General Discussion)
by ERR 2/28/2015 6:18:25 PM(UTC)
Vertical scroll bar (Feature Requests)
Belarus pasingshot 7/15/2014 4:53:21 AM(UTC)
Scroll Divider (Feature Requests)
by Yaamin 9/6/2013 2:25:46 PM(UTC)
Scroll in encoder window/log (General Discussion)
by sportzcast 7/23/2013 5:41:47 PM(UTC)
