mkobzar
#1 Posted : 8 years ago
mkobzar
4K input and some HD virtual inputs.
http://www.datavideo.com/product/KMU-100
Is it possible?
Peter B
#2 Posted : 8 years ago
Peter B
You can do that now with vMix 4K and then transition between the new shots with the merge function.
mattd
#3 Posted : 8 years ago
mattd
Good answer Peter! having recently tested this out it works really well. Another method is using a blank virtual set and use the 4k input as a layer. Then you can choose to cut or pan transitions etc with the four position available. Which you can also do with multiple virtual inputs.
daniel514
#4 Posted : 8 years ago
daniel514
Canada
Was thanked: 15 time(s) in 15 post(s)
Yes cropping could be amazing!
Add to it a joystick controller and WOW!
I tried to suggest similar concept but got NO interest at all from users or developpers... maybe was not clear enough in my description?
https://forums.vmix.com/default.aspx?g=posts&t=5264
