mkobzar
#1 Posted : Wednesday, May 24, 2017 10:50:29 PM(UTC)
mkobzar
4K input and some HD virtual inputs.
http://www.datavideo.com/product/KMU-100
Is it possible?
Peter B
#2 Posted : Wednesday, May 24, 2017 11:27:09 PM(UTC)
Peter B
You can do that now with vMix 4K and then transition between the new shots with the merge function.
mattd
#3 Posted : Thursday, May 25, 2017 4:37:11 AM(UTC)
mattd
Good answer Peter! having recently tested this out it works really well. Another method is using a blank virtual set and use the 4k input as a layer. Then you can choose to cut or pan transitions etc with the four position available. Which you can also do with multiple virtual inputs.
daniel514
#4 Posted : Friday, June 9, 2017 9:56:33 AM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
Yes cropping could be amazing!
Add to it a joystick controller and WOW!
I tried to suggest similar concept but got NO interest at all from users or developpers... maybe was not clear enough in my description?
https://forums.vmix.com/default.aspx?g=posts&t=5264
