Feature Requests
Want multicam option. Like Datavideo KMU-100 4K
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
You can do that now with vMix 4K and then transition between the new shots with the merge function.
Joined: 5/25/2017(UTC) Posts: 1 Location: Wellington NZ
Good answer Peter! having recently tested this out it works really well. Another method is using a blank virtual set and use the 4k input as a layer. Then you can choose to cut or pan transitions etc with the four position available. Which you can also do with multiple virtual inputs.
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
Yes cropping could be amazing! Add to it a joystick controller and WOW!  I tried to suggest similar concept but got NO interest at all from users or developpers... maybe was not clear enough in my description? https://forums.vmix.com/default.aspx?g=posts&t=5264
Feature Requests
