Livenet_Thomas
#1 Posted : Friday, May 12, 2017 11:39:42 AM(UTC)
Livenet_Thomas
Hello Community
I'm quite new with vMix and Streaming at all.
I work in a little Company and we'd like to dub a stream of
an other provider. We have the permission and we will get access.
But we'd like to test that beforehand. So my goal was to set up an
devloping system with vMix in the test version.
I did a lot of research. Anyhow i could not get it to work.
First i tried to setup a stream in youtube and then to get that stream
into vmix. But I could not set the rtmp-link provided by YouTube as Input
in vMix.I assume it's because YouTube blocks the access on the rtmp-server.
After that I tried to setup a stream on streamzilla, which was no problem.
But when tried to set this stream as inputsource for vMix, it did not work
either. I'm not sure what i did wrong. Here are the URL's I tried to get the
connection going:
- rtmp://wos.in1.streamzilla.xlcdn.com/live/sz=livenet=event02?[user]&[password]
I hope this is not a very newbie Question. But I found it really difficult to find the
right information. Altough I checked any vMix resources (Help, FAQ, etc.), I could find.
Thanks for any respone.
Thomas
#2 Posted : Friday, May 12, 2017 11:59:31 AM(UTC)
Hi Thomas
You are confusing the address for publishing a RTMP stream TO a server with the address (URL) for playing this stream FROM the server.
Check the doc here : http://www.vmix.com/help19/Flash.html
You can PLAY any video from YouTube in vMix using the Flash/RTMP input type with this syntax :
http://www.youtube.com/v/VIDEO_ID
As of streamzilla, I'm not sure they provide the RTMP protocol for PLAYING the video.
As the case may be, do not use the codes for ingestion, but the URL they provide to play the video
Hope this helps
Guillaume
Similar Topics
vMix crash with RTMP input after Windows update (General Discussion)
by Llorx 5/20/2018 8:25:43 AM(UTC)
Replay with RTMP input (Instant Replay)
by atvtest 4/7/2018 6:01:57 AM(UTC)
RTMP Input revamp (Feature Requests)
by Yamato 12/8/2017 8:30:54 PM(UTC)
Volume Activator not working on Video and FLAS / RTMP Input (Hardware Compatibility)
by Aki 8/14/2017 8:27:30 AM(UTC)
Flash RTMP Input issue on Windows 10 (General Discussion)
by Kaf 9/28/2016 11:24:39 AM(UTC)
Newest VMIX causes loss of audio on rtmp inputs (General Discussion)
by djevo1 5/10/2016 7:37:56 PM(UTC)
http/mms/rtmp input (Feature Requests)
by mitchstein443 4/18/2015 4:57:19 AM(UTC)
RTMP inputs capped to 30p? (General Discussion)
by dashner 1/10/2015 9:50:29 AM(UTC)
Multiple RTMP input performances (General Discussion)
by Julian 9/19/2014 6:42:12 AM(UTC)
RTMP Input Freezes after a few seconds (General Discussion)
by dodgepong 5/13/2014 2:10:42 AM(UTC)
RTMP input - Dacast.com (General Discussion)
by ClementN 2/14/2014 4:51:26 PM(UTC)
RTMP input audio balance question (General Discussion)
by elduran 1/27/2014 1:42:51 PM(UTC)
