Dailymirror
#1 Posted : Thursday, January 27, 2022 4:06:06 AM(UTC)
Dailymirror
We are using vMix both to output the primary Program feed as a live stream but then we also use the same instance of vMix to feed an on-set monitor via a Mix 2. Is there anyway to send my main Program to my Mix 2 so that the feed can come up on the on-set monitor?
Thanks!
B
ggudnason
#2 Posted : Thursday, January 27, 2022 5:31:51 AM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
You can either loop back in the program via NDI and then set that input to mix2. Or you could simply set shortcuts to change the output that you use for the on set monitor. From program to mix2 and vice versa.
thanks 1 user thanked ggudnason for this useful post.
Dailymirror on 1/27/2022(UTC)
Dailymirror
#3 Posted : Thursday, January 27, 2022 7:25:58 AM(UTC)
Dailymirror
Yep! About ten minutes after I posted this I thought of the NDI work around. Thanks so much!
B
richardgatarski
#4 Posted : Thursday, January 27, 2022 6:15:19 PM(UTC)
richardgatarski
