Hi Richard...any updates soon?.....looking forward to seeing some new stuff.....
Joeboe
Hi Raugert, I have an issue.....I know that vMix has stopped DynamicScripting from external app by vMix, and now none of my scripts work in 24:72.....is tere a way to get them to work again , as I need most of these scripts for my productions...
Thanks, joeboe
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
@Joeboe
Yes indeed, as of vMix version 24.0.0.60 the TCP and Web API are now locked down by 'default' with some enhanced security measures. This essentially blocks the "StartScriptDynamic" command.
There are 2 options:
1. You can choose to disable the "Enhanced Security" option in the vMix Web settings if you wish. This would allow the Dynamic scripts to run again but you will lose the enhanced security features if that is important to you.
2. You can Export the scripts from the Panel Builder app and then Import them into vMix giving them a unique name. You would then call up the scripts directly using the "ScriptStart" command.
cheers, Richard
I tried unticking the "Enhanced Security" option but it is still not working.....don't know why....I am on 24:...72, maybe that was fully disabled.......and I can not import the script after exporting from Panel Builder...I keep getting an error....cannot find script.....am I exporting or naming the script incorrectly....please give an example, so I can see where I am going wrong....
Joined: 4/30/2020(UTC) Posts: 35  Location: Monza Was thanked: 1 time(s) in 1 post(s)
I am using excel as a source for several contents, first of all lower thirds I would like to manage the excel data as i do with lists: I have a videolist object on the panel, and I interact with single items with buttons
I have seen the "datasources" section in the possible actions i can assign to a button, but i can't see how to visualize the "excel database list" on the tablet does anyone has some suggestion?
thank you very much
Another question: is it possible to change the color of a button based on its state and not tally? a sort of on/off?
UPDATE Version 4.0.32 Note: (This version and future updates must use vMix23 or above) https://cli.re/vMix-Panel-Builder-4.0.32- Added positional feedback when using "SetGain" command in a slider - Fixed BusXAudio tally -- broke it in 4.0.29 - Added ability to use Input number for Title and List objects - Added "Locate Panel" command (Cmd-L on Mac or CTL-L on PC). Allows users to locate a panel that was designed on larger or second screen and not visible on current screen. - Fixed issue where "Delete" key on PC was deleting random objects (If this persists with some keyboards, use Backspace" key to delete objects) - VU meters can now be made Horizontal by dragging resize handles - Fixed tallies when using "set text as Button Info" - Moved Prefs UI to a floating window (Better UI when designing smaller templates) - Added pulldown menu for up to 8 vMix IPs (can still only control 1 vMix machine at a time) - Fixed issue when copying objects from one page to another when clicking on target canvas before pasting objects - Improved tallies when using Dynamic Inputs (1-4). - Added SetVolumeChannelMixer command - Can now sync UserIcons to iPad from selected "Default UserIcon directory" set in preferences. Would only sync previously from Document/vMix Panel Builder/UserIcons directory - Added "URL Command Line " when selected command is 'Launch Ext Pgm' (sends the command to a URL without opening a browser) - Set text size of Title and VideoList objects now applies to all fields. Field sizes adjust dynamically to selected text size. - Fixed flickering when resizing some objects - other minor bug fixes
Joined: 4/23/2020(UTC) Posts: 8   Location: Maresme Thanks: 5 times
No works with Video List. Not show the list. Can anybody test this ?
I test several times. The version 29 is good in this but 32 no.
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Hi, version 32 is not working well, from what I tried this I found. - VideoList does not work - Vumeter - The application does not close (Yes button does not work to confirm close application)
Thanks for the reports. I will fix these issues as soon as possible. I've discovered a bug when using "Input Number" instead of "Input Name" in the objects. That may be the cause of some issues.
I made several changes in the last version and inevitably caused some bugs... :(
thanks for your patience. Richard
Hi Richard, the file is saying 4.0.33, instead of 4.0.34...
thanks.
Thanks for the heads up JoeBoe,
You can re-download it. It should be correct now..
 1 user thanked raugert for this useful post.
Hi, I’m working on 24.0.0.7, / Windows panel desktop 4.0.35.
When I try to import the custom icons from buttons on my template, the jpg files transfer but do not show on buttons. I have tried rebooting and reloading both sides of the program. No luck. IOS 14 on iPad Pro 2021
I find this was happening from very early, but never report it as a bug....I just close Panel Builder and reopen it and all is well.....I save as.. first, and then close.....I thought it was my system being too slow, but since it was fixed with a restart, I just don't bother.....
@ TracyPeterson Can you send me a couple of your custom icons and your panel template to info@studio793.ca I'll have a look at it and see what might be happening. thanks, Richard
Hi all,
im using the new update of panel builder but i still don't have a tally on the "auto audio toggle" feature. Will it be possible to bring it to the next update?
Kind regards Ruben
Unfortunately the "Audio Auto Toggle" information is not available in the vMix API, therefore I cannot update a tally for that function.
I believe that Martin at vMix mentioned on their last "FunTime" show that they will add some more information in the API XML in vMix 25. It might be worth adding a feature request on the forum for that.
