CyberPunk1232
#1 Posted : Saturday, November 27, 2021 1:39:49 PM(UTC)
CyberPunk1232
New Zealand
Purchased a capture card. Blackmagic decklink duo 2 SDI, I have a camera with an SDI output, when I plug it into the computer it doesn't work. How can this issue be resolved, I have all the software updated and all the frame rates are running the same. I also have a BlackMagic ATEM switcher, The camera we are using is a SONY HXR-NX100! can anyone heko
xaver
#2 Posted : Saturday, November 27, 2021 5:27:34 PM(UTC)
xaver
with resolution and framerate?
did you try 720p?
3G SDI sometimes has problems with BMD Devices (SDI Level A and Level B)
Also try Black Magic Media Express, if you get the video there
the tecch data sheet of the camera says nothing about SDI Out, only HDMI and Composite
https://pro.sony/s3/cms-...ile/66/1237493716066.pdf
which HDMI to SDI do you use?
CyberPunk1232
#3 Posted : Saturday, November 27, 2021 5:36:53 PM(UTC)
CyberPunk1232
New Zealand
Its a sdi to sdi capture card :)
MartLeib
#4 Posted : Saturday, November 27, 2021 6:19:01 PM(UTC)
MartLeib
Estonia
Does the card appear in Desktop Video Setup?
Does the fan on the card spin?
Do the card inputs appear in Media Express "Device" list?
xaver
#5 Posted : Saturday, November 27, 2021 6:49:30 PM(UTC)
xaver
But the camera has no SDI
Joeboe
#6 Posted : Saturday, November 27, 2021 8:37:00 PM(UTC)
Joeboe
I have similar problem with the BMC Duo, I only see 1 input instead of 2....this has me puzzled
xaver
#7 Posted : Saturday, November 27, 2021 10:07:06 PM(UTC)
xaver
you have to go to the settings of the BMD Desktop Video setup and set the connector mapping correct
Joeboe
#8 Posted : Sunday, November 28, 2021 8:54:50 AM(UTC)
Joeboe
I tried that, but it does not seem to work:
I do not see a choice, just a single input, nothing to choose other than type of input....and nothing over 9.53 would install, it keeps rollong back and giving an error....Cannot install any drivers over 9.53
mcollege
#9 Posted : Tuesday, November 30, 2021 8:37:38 AM(UTC)
mcollege
That camera doesn't look like it support SDI which is digital. It has a BNC connector but it's analogue only.
It does have a HDMI output so you can probably get it to work with a BlackMagic micro HDMI->SDI converter (set to SDI output level B) and do it that way.
Guest (4)
