KJPark
#1 Posted : Sunday, November 14, 2021 9:02:13 AM(UTC)
KJPark
Norway
I might be picky. But on a production set for a company the director always called "Dissolve" as "fade".
In reality a dissolve is the term for crossfade. In vMix it is called Fade which might be confusing to proper terminology? It's weird to have the director call dissolve, but you have to remember to press Fade.
#2 Posted : Sunday, November 14, 2021 10:36:21 AM(UTC)
Would a change in the language file not help ?
KJPark
#3 Posted : Sunday, November 14, 2021 11:51:04 AM(UTC)
KJPark
Norway
Is that possible? Where is it located and called? Guess I could just do it with Notepad++
BETech
#4 Posted : Sunday, November 14, 2021 12:05:03 PM(UTC)
BETech
The language of television production, and the ambiguity in vMix.
A fade generally refers to a fade ... to black (FTB).
A Mix or Dissolve refers to a transition between two video sources.
The vMix Mix Input refers to a Mixed Effects bus or ME bus/row, where two sources can be transitioned and video keys applied.
So the ‘vMix Input’ should be renamed ‘Mixed Effects’ or ‘M.E.’
Overlay is the term used to place video footage over an interview or voice-over. Also referred to as ‘B Roll’ in some countries.
Video Key is the correct term, whereby the Video Key includes the ‘Key Fill’ and the ‘Key Alpha’.
The Alpha cuts the hole in the background image, and the Fill as the word implies, Fills the Key Alpha hole.
Button Tally like camera tally, also referred to as Activators, which is fresh new name. All good there.
We can always count on Doggy for a smile :)
#5 Posted : Sunday, November 14, 2021 6:56:02 PM(UTC)
VMix directory (in Program Files (x86)), subfolder "languages".
Why not add a Norwegian language file while at it ?
KJPark
#6 Posted : Monday, November 15, 2021 3:15:19 AM(UTC)
KJPark
Norway
Funny. I've begun to translate to Norwegian per your idea :)
But I can't change "Fade" to "Dissolve" or anything else. other texts responds right away and changes the language. But Fade is still stucked as Fade. Do you have any ideas why?
#7 Posted : Monday, November 15, 2021 4:07:41 AM(UTC)
I noticed that too. seems to be all the ones that have a dropdown available that do not respond to it. probably an oversight (bug) as else the translation being available is of no use.
But we all know a person who should know ;-)
KJPark
#8 Posted : Monday, November 15, 2021 4:16:05 AM(UTC)
KJPark
Norway
Aha, I see. Thank you Doggy for your quick response and being so helpful :) One day, "Fade" will be "Dissolve". Until then, we'll have to fade that wish away.
#9 Posted : Monday, November 15, 2021 4:33:33 AM(UTC)
By that time you will bo so used to "Fade" that you will wonder what "Dissolve" means LOL
And what about "Merge" ? ;-)
In vMix speak what is it ? the sugar in my coffee fades or merges ?
