Feature Requests
Fade is actually dissolve
I might be picky. But on a production set for a company the director always called "Dissolve" as "fade".
In reality a dissolve is the term for crossfade. In vMix it is called Fade which might be confusing to proper terminology? It's weird to have the director call dissolve, but you have to remember to press Fade.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Would a change in the language file not help ?
Originally Posted by: doggy  Would a change in the language file not help ? Is that possible? Where is it located and called? Guess I could just do it with Notepad++
Joined: 5/18/2015(UTC) Posts: 150 Location: Australia
Thanks: 81 times Was thanked: 110 time(s) in 71 post(s)
The language of television production, and the ambiguity in vMix.
A fade generally refers to a fade ... to black (FTB).
A Mix or Dissolve refers to a transition between two video sources.
The vMix Mix Input refers to a Mixed Effects bus or ME bus/row, where two sources can be transitioned and video keys applied. So the ‘vMix Input’ should be renamed ‘Mixed Effects’ or ‘M.E.’
Overlay is the term used to place video footage over an interview or voice-over. Also referred to as ‘B Roll’ in some countries. Video Key is the correct term, whereby the Video Key includes the ‘Key Fill’ and the ‘Key Alpha’. The Alpha cuts the hole in the background image, and the Fill as the word implies, Fills the Key Alpha hole.
Button Tally like camera tally, also referred to as Activators, which is fresh new name. All good there.
We can always count on Doggy for a smile :)
Originally Posted by: KJPark  Originally Posted by: doggy  Would a change in the language file not help ? Is that possible? Where is it located and called? Guess I could just do it with Notepad++ VMix directory (in Program Files (x86)), subfolder "languages". Why not add a Norwegian language file while at it ?
Originally Posted by: doggy  Originally Posted by: KJPark  Originally Posted by: doggy  Would a change in the language file not help ? Is that possible? Where is it located and called? Guess I could just do it with Notepad++ VMix directory (in Program Files (x86)), subfolder "languages". Why not add a Norwegian language file while at it ? Funny. I've begun to translate to Norwegian per your idea :) But I can't change "Fade" to "Dissolve" or anything else. other texts responds right away and changes the language. But Fade is still stucked as Fade. Do you have any ideas why?
Originally Posted by: KJPark  Funny. I've begun to translate to Norwegian per your idea :)
I noticed that too. seems to be all the ones that have a dropdown available that do not respond to it. probably an oversight (bug) as else the translation being available is of no use. But we all know a person who should know ;-)
Originally Posted by: doggy  Originally Posted by: KJPark  Funny. I've begun to translate to Norwegian per your idea :)
I noticed that too. seems to be all the ones that have a dropdown available that do not respond to it. probably an oversight (bug) as else the translation being available is of no use. But we all know a person who should know ;-) Aha, I see. Thank you Doggy for your quick response and being so helpful :) One day, "Fade" will be "Dissolve". Until then, we'll have to fade that wish away.
Originally Posted by: KJPark  One day, "Fade" will be "Dissolve". Until then, we'll have to fade that wish away. By that time you will bo so used to "Fade" that you will wonder what "Dissolve" means LOL And what about "Merge" ? ;-) In vMix speak what is it ? the sugar in my coffee fades or merges ?
Feature Requests
