Hard Knox Talks
#1 Posted : Saturday, November 13, 2021 12:20:59 AM(UTC)
Hard Knox Talks
Canada
Hey all, new here. When I try to add a second vMix call to my production, The second call doesn't work about half the time, even from multiple different devices and settings. I don't know how to explain it but if I remove the first caller, then add the second caller it works, i can then add the first caller with a new link, its very confusing. I hope that makes sense, has anyone experienced this? I cant seem to find any information on this specific scenario.
mavik
#2 Posted : Sunday, November 14, 2021 5:07:15 AM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
What license are you on
Hard Knox Talks
#3 Posted : Sunday, November 14, 2021 6:36:46 AM(UTC)
Hard Knox Talks
Canada
vMix Pro. is that what you mean?
mavik
#4 Posted : Sunday, November 14, 2021 6:50:59 AM(UTC)
mavik
Ok, with PRO you have 8 calls. I thought initially you might be on HD which is just one call.
I just did a show with several calls this week and no issues.
The calls are based on webRTC. Apart from the license level there shouldn't an limitations on it technically. I assume your bandwidth available isn't a bottleneck.
Chris Daum
#5 Posted : Sunday, November 21, 2021 10:46:23 AM(UTC)
Chris Daum
Germany
possibly a network issue.
Run a speedtest, if the result is good
then monitor your network.
couple of NDI streams in the network?
lot of guests causing a lot of traffic?
from the vMix place lot of components (switchers and all that stuff) to the internet?
many possible reasons!
Similar Topics
Multiple to multiple VMIX calls audio issues (vMix Call)
by Ronp@hakolsound.co.il 10/23/2020 5:05:02 AM(UTC)
