guztavo
#1 Posted : Monday, November 1, 2021 2:41:46 AM(UTC)
guztavo
Hi.
Writing because after formating my PC with vMix 23, now i'm trying to install vMix 24 but i can't actívate it.
I have my HD license, tested on vMix if is able to work with v24 and all is right.
Here is the error. If try to do a 60 days trial same error: https://ibb.co/7KPJGQT
Tried the vMix 23 installer and get the same. Did you see this issue before?
Thanks in advance
eduardocfs
#2 Posted : Monday, November 1, 2021 2:56:15 AM(UTC)
eduardocfs
Brazil
Was thanked: 19 time(s) in 8 post(s)
Guztavo, it is possible that your HOST file must have been changed. Go to the c:/windows/system32/drivers/etc directory. Make a copy of your HOST file on your desktop. Edit the file in Desktop removing any lines that have reference to "vmix". Rename the original host file on etc directory . And replace with the new edited file.
thanks 1 user thanked eduardocfs for this useful post.
guztavo on 11/1/2021(UTC)
guztavo
#3 Posted : Monday, November 1, 2021 3:28:32 AM(UTC)
guztavo
Thanks for your help!
The hosts file it's clear, as the machine has been formatted yesterday:
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
Thanks again!
guztavo
#4 Posted : Monday, November 1, 2021 3:51:52 AM(UTC)
guztavo
Found that when opening "vMix Update" get this error: Could not check version on vMix web site, check your internet connection and try again.
Seems to be that my PC can't Access to vMix servers...
guztavo
#5 Posted : Tuesday, November 2, 2021 7:48:21 PM(UTC)
guztavo
guztavo
#6 Posted : Tuesday, November 2, 2021 11:14:44 PM(UTC)
guztavo
Have a coming venue soon... any ideas?
Thanks!
MartLeib
#7 Posted : Wednesday, November 3, 2021 12:29:11 AM(UTC)
MartLeib
Estonia
Have you tried another internet connection? I have had a similar problem with my home network but using 4G the activation worked flawlessly.
#8 Posted : Wednesday, November 3, 2021 8:09:49 PM(UTC)
@ guztavo
Are you running the latest Windows 10?
As Microsoft no longer supports Windows 7, systems running that OS are missing the current security protocols required to connect to the vMix servers:
https://www.vmix.com/kno...egister-or-activate-vmix
LemkeFH
#9 Posted : Tuesday, January 18, 2022 4:17:43 AM(UTC)
LemkeFH
Guztavo, I know this was from a few months ago, but did you ever find a solution? I am having a similar problem. Thank you
