Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi. Writing because after formating my PC with vMix 23, now i'm trying to install vMix 24 but i can't actívate it. I have my HD license, tested on vMix if is able to work with v24 and all is right. Here is the error. If try to do a 60 days trial same error: https://ibb.co/7KPJGQTTried the vMix 23 installer and get the same. Did you see this issue before? Thanks in advance
Joined: 4/27/2018(UTC) Posts: 33   Location: Brazil Thanks: 400 times Was thanked: 19 time(s) in 8 post(s)
Guztavo, it is possible that your HOST file must have been changed. Go to the c:/windows/system32/drivers/etc directory. Make a copy of your HOST file on your desktop. Edit the file in Desktop removing any lines that have reference to "vmix". Rename the original host file on etc directory . And replace with the new edited file.
 1 user thanked eduardocfs for this useful post.
Originally Posted by: eduardocfs  Guztavo, it is possible that your HOST file must have been changed. Go to the c:/windows/system32/drivers/etc directory. Make a copy of your HOST file on your desktop. Edit the file in Desktop removing any lines that have reference to "vmix". Rename the original host file on etc directory . And replace with the new edited file. Thanks for your help! The hosts file it's clear, as the machine has been formatted yesterday: # Copyright (c) 1993-2009 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host # localhost name resolution is handled within DNS itself. # 127.0.0.1 localhost # ::1 localhost Thanks again!
Found that when opening "vMix Update" get this error: Could not check version on vMix web site, check your internet connection and try again. Seems to be that my PC can't Access to vMix servers...
Have a coming venue soon... any ideas? Thanks!
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Have you tried another internet connection? I have had a similar problem with my home network but using 4G the activation worked flawlessly.
Joined: 3/7/2012(UTC) Posts: 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
Guztavo, I know this was from a few months ago, but did you ever find a solution? I am having a similar problem. Thank you
