Feature Requests
Allow option for input's main position to be adjusted without affecting MultiView Overlays
Joined: 7/4/2021(UTC) Posts: 420  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Right now, when adjusting the main position of an input, the positions of any MultiView Overlays on that input are also adjusted, so that they remain in place & proportional, relative to the main input.
While I can appreciate that there are situations where that's beneficial, there are also situations where it's far more of a hindrance than a help.
Accordingly, a checkbox or something to maintain the MultiView Overlay positioning while the input's main positioning is adjusted would be greatly appreciated.
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 13 time(s) in 8 post(s)
Have you considered using a black or transparent background for the main layer and then adding your ACTUAL main layer in the LAYER-1 position? That way you can adjust all layers independently from each other.
Best,
David
It's an option.
It's not ideal, as it removes the Pause/Play controls & time remaining when it's a video, unless I put the video itself in the preview screen, which ultimately makes me choose between those controls & information or an accurate preview.
But it is an option.
Feature Requests
