WaltG12
#1 Posted : Thursday, October 28, 2021 8:22:02 AM(UTC)
WaltG12
Right now, when adjusting the main position of an input, the positions of any MultiView Overlays on that input are also adjusted, so that they remain in place & proportional, relative to the main input.
While I can appreciate that there are situations where that's beneficial, there are also situations where it's far more of a hindrance than a help.
Accordingly, a checkbox or something to maintain the MultiView Overlay positioning while the input's main positioning is adjusted would be greatly appreciated.
David_in_Philly
#2 Posted : Friday, October 29, 2021 9:33:53 AM(UTC)
David_in_Philly
Was thanked: 14 time(s) in 9 post(s)
Have you considered using a black or transparent background for the main layer and then adding your ACTUAL main layer in the LAYER-1 position? That way you can adjust all layers independently from each other.
Best,
David
WaltG12
#3 Posted : Friday, October 29, 2021 2:32:11 PM(UTC)
WaltG12
It's an option.
It's not ideal, as it removes the Pause/Play controls & time remaining when it's a video, unless I put the video itself in the preview screen, which ultimately makes me choose between those controls & information or an accurate preview.
But it is an option.
