Hi all, I think this was mentioned before, but I can not find the posts....which AMD Ryzen CPU is recommended for use with vMix.....I have an offer to buy an AMD system, but I only want something that will work with vMix.
Thanks in advance
If you want a PC like the Opal reference system ( see here) you could use the AMD Ryzen 5 3600X, and you'll also notice a couple of Sapphire laptop options use the AMD Ryzen 7 5800H, so the AMD Ryzen 7 5800X desktop version should be OK too, assuming you're not looking for a laptop.
 1 user thanked zenvideo for this useful post.
Thanks....I saw that, but am looking for the lowest AMD model that will work with vMix....I was looking at the Asus PRIME X570-PRO Ryzen 3 AM4 ...... will this work?
You have been a member since:: 10/7/2015(UTC) Posts: 635 Location: California
According to the ASUS website, the PRIM X570-PRO supports 3rd gen Ryzen CPUs. Doesn't the AMD system you want to buy come with a CPU?
