Joeboe
#1 Posted : Tuesday, October 26, 2021 9:49:17 PM(UTC)
Joeboe
Hi all, I think this was mentioned before, but I can not find the posts....which AMD Ryzen CPU is recommended for use with vMix.....I have an offer to buy an AMD system, but I only want something that will work with vMix.
Thanks in advance
zenvideo
#2 Posted : Wednesday, October 27, 2021 1:22:19 AM(UTC)
zenvideo
If you want a PC like the Opal reference system (see here) you could use the AMD Ryzen 5 3600X, and you'll also notice a couple of Sapphire laptop options use the AMD Ryzen 7 5800H, so the AMD Ryzen 7 5800X desktop version should be OK too, assuming you're not looking for a laptop.
Joeboe on 10/27/2021(UTC)
Joeboe
#3 Posted : Wednesday, October 27, 2021 2:22:03 AM(UTC)
Joeboe
Thanks....I saw that, but am looking for the lowest AMD model that will work with vMix....I was looking at the Asus PRIME X570-PRO Ryzen 3 AM4 ...... will this work?
SportsNetUSA.net
#4 Posted : Wednesday, October 27, 2021 3:15:16 AM(UTC)
SportsNetUSA.net
According to the ASUS website, the PRIM X570-PRO supports 3rd gen Ryzen CPUs. Doesn't the AMD system you want to buy come with a CPU?
Similar Topics
vMix: Motherboard for AMD RYZEN 7 9700X (Hardware Compatibility)
by arszu 11/1/2025 7:31:53 AM(UTC)
SRT Output Not working/Showing on Acer Nitro 5 with AMD Ryzen 7 (SRT)
by envideano 9/26/2024 7:18:55 PM(UTC)
Amd Ryzen 5 5600 vs 5600G (Systems)
by Chromascope 6/16/2024 11:55:20 AM(UTC)
Vmix Crash - Camera Inputs in pc amd ryzen 5 (Hardware Compatibility)
by AD ASSIS SP 11/26/2022 12:42:07 AM(UTC)
AMD Ryzen 5 4600H / ​NVIDIA GTX 1650 vMix Perfomance? (Systems)
by tsioukas 8/2/2021 4:49:17 PM(UTC)
vMix + AMD RYZEN 2700x (Systems)
by euomauricio 3/24/2020 6:06:14 AM(UTC)
(4K BUILD) Intel Core i9-7940X VS AMD Ryzen Threadripper 2950X (Systems)
by manuelgomezo 4/4/2019 1:19:21 AM(UTC)
AMD Ryzen and Vmix (Hardware Compatibility)
by goaliebob99 3/1/2019 3:03:43 AM(UTC)
New AMD Ryzen Computer Build with vMix (Systems)
Belarus RichShumaker 3/21/2017 6:15:34 PM(UTC)
AMD Ryzen on vMix? (Hardware Compatibility)
by RC_31 2/28/2017 6:51:35 PM(UTC)
