Rich1000
#1 Posted : Thursday, October 21, 2021 1:35:19 AM(UTC)
Rich1000
I have a client that uses the Basic HD version of VMIX.
If I open that file with the Pro Version... Will I be able to use all the Pro version attributes (layers,inputs and controls, etc.).
Or does it keep it as a Basic HD file?
Thanks,
Richard
richardgatarski
#2 Posted : Thursday, October 21, 2021 2:38:36 AM(UTC)
richardgatarski
Yes you can open it.
Opening Presets in a lower edition than originally saved in typically retains all Inputs, but makes the "overflowed" Offline (i.e. unusable)
Rich1000
#3 Posted : Thursday, October 21, 2021 6:15:30 AM(UTC)
Rich1000
richardgatarski,
Thanks for the info...very helpful.
I will call my client and let them know.
Thank you again,
Richard
