Can Basic HD file be open in PRo version
I have a client that uses the Basic HD version of VMIX. If I open that file with the Pro Version... Will I be able to use all the Pro version attributes (layers,inputs and controls, etc.).
Or does it keep it as a Basic HD file?
Thanks,
Richard
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Yes you can open it. Opening Presets in a lower edition than originally saved in typically retains all Inputs, but makes the "overflowed" Offline (i.e. unusable)
richardgatarski,
Thanks for the info...very helpful.
I will call my client and let them know.
Thank you again,
Richard
