4 Pages«<234
xun
#61 Posted : Saturday, September 11, 2021 10:59:06 AM(UTC)
xun
Germany
vMix-API delivers wrong GAIN value for all audio channels until the value changes.
1. create new project
2. change audio gain value
3. save project and reopen it
4. check API-XML for the gain value and the real set gain -> its not the same until the gain value changes via fader, midi-cmd, ... then the xml value is updated correctly.
JimJim
XUN
#62 Posted : Saturday, September 11, 2021 12:57:56 PM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
I cannot replicate that behavior.
Note that gainDb is a floating point value, and may be a slightly different fraction to what is displayed on screen in vMix.
(3.9 vs 4 in vMix).
This is unavoidable and you can round the value to 0 decimal places yourself if you require.
xun
#63 Posted : Sunday, September 12, 2021 4:49:54 AM(UTC)
xun
Germany
Hi .. sry, i was confuses ... it was my mistake. My problem is created by the not existing activator for "gain" for my behringer knob's.
JimJim
XUN
ysidea
#64 Posted : Sunday, September 12, 2021 10:00:14 PM(UTC)
ysidea
Canada
Originally Posted by: suburbazine Go to Quoted Post
I've encountered an NDI issue in V24, one that's not present in V23. (latest versions of each)
The issue was also present in the prerelease version of v24 but I guess I shouldn't have marked it off as something that was just a beta thing.
The issue with NDI is the encoder transport from vMix output is dropping bursts of frames every few seconds, running 1080p59.94. It happens on all resolutions and the current system is at less than 15% utilization. Reverting back to v23 with same settings has no issue.
NDI input seems unaffected.
i9-9980XE
Quadro P5000
128GB RAM
10Gbe NICs
Hi, I also happenned to have the same issue as you around the same time (in February) I also have about the same specs as you on my system. I'm using an RME Dante as my audio interface. And I actually started getting dropped frame starting the 20H2 windows update.
So my issue wasn't NDI but it was my sound. The sound glitches weren't noticeable during speaking event, but in live music show, it was noticeable. Using LatencyMon showed me that the new wdf01000.sys causing high latency at the exact same time I was getting audio drop out and NDI glitches.
I end out using my Usb-c port on my GPU (different chipset/driver) and had no issue since. I believe it was fix in Kb5004296 but I haven't extensively tested it. I also made a small startup script that move my audio drivers threads onto cpu core other than 0 and 1.
I'm just leaving that comment, a bit late, in case it might help someone.
umek
#65 Posted : Friday, September 17, 2021 4:24:31 AM(UTC)
umek
Hi!
Can you share the startup script?
Thx
ron2210
#66 Posted : Tuesday, October 19, 2021 4:06:38 PM(UTC)
ron2210
India
Possible Bug:
When manually entering Virtual Set Speed,
Keyboard Shortcuts associated with those keys are executed even though focus is on Edit Box
Chap
#67 Posted : Thursday, December 16, 2021 4:06:29 AM(UTC)
Chap
External output is not initialized correctly (vMix 24.0.0.72)?
This happened after installing the latest drivers (12.2.2) for BMD DeckLink Duo 2.
The External output is configured output to one of the SDI-connectors on the DeckLink Duo 2 (it has 4 SDI connectors).
External output resolution (for external recorder) is set to 720P50, Master Output is 1080P50.
This worked quite reliable before with 12.0 drivers.
I still can get it to work with 12.2.2 drivers by changing the output resolution in External Output Settings. This seems to trigger it correctly.
Please fix ASAP.
melody
#68 Posted : Wednesday, January 12, 2022 4:33:12 AM(UTC)
Rank: Guest
Groups: Guests
Hi admin,
Founded a bug with my elgato hd60 pro.
The card works fine but every time i close vMix it gets unresponsive until i kill elgato game capture app on task manager, so then vMix close totaly.
Today i did a clean install of Windows 10 21h2 and the issue presist.
I followed the instructions on vMix web site (link below):
https://www.vmix.com/kno...apture-devices-with-vmix
Cheers,
Melody
melody
#69 Posted : Tuesday, February 1, 2022 3:59:47 AM(UTC)
Rank: Guest
Groups: Guests
Originally Posted by: melody Go to Quoted Post
Hi admin,
Cheers,
Melody
update: i fixed it by changing to the right source. i get 2 video inputs just for my elgato hd60 pro, it was confusing to me.
melody
#70 Posted : Tuesday, February 1, 2022 4:06:02 AM(UTC)
Rank: Guest
Groups: Guests
i founded another bug,
i have 2 hdmi-to-usb video capture. on "Add New Input" tab, when i add them to vmix with vmr7 checked, vmix freeze completely. i need to kill vMix on task manager.
i can share more information if need.
cheers,
melody
melody
#71 Posted : Saturday, February 5, 2022 8:42:58 AM(UTC)
Rank: Guest
Groups: Guests
Hi admin,
Founded a bug with vMix 24 on today's livestream. I know vMix dont have officialy support to Windows 11, but maybe others can face this issue also... during production, vMix closed and oppened itself showing the issue below:
https://mega.nz/file/uBx...KUVfXhCodrRE7qtNo5HU4BiQ
My config:
SO: WINDOWS 11 PRO
Motherboard: ASUS TUF Z370-PRO Plus
CPU: Intel i5 8600k 4.5GHz OC
CAP DEV: 2x AVerMedia Live Gamer HD 2 and Elgato HD60 Pro
RAM: HyperX 2x 8GB 2666mhz
GPU: NVIDIA GTX 1650 SUPER 4GB
SSD: Crucial MX500 512GB
Guest (10)
4 Pages«<234
