fabfab10
#1 Posted : Wednesday, September 29, 2021 8:25:19 PM(UTC)
fabfab10
Groups:: Registered
Italy
i would like to create a custom stinger with a logo image with key to be used for replay transition like the one in the example below:
Custom Stinger
[YOUTUBE]https://youtu.be/SSYVEycV1Os?t=5229[/YOUTUBE]
Using GT Designer i haven't found the way to zoom the image out as much as needed to cover the upcoming source (replay A or B).
Any suggestion how to do this?
Thank you in advance
#2 Posted : Thursday, September 30, 2021 12:50:44 AM(UTC)
Preferably one woud create a image sequence with some other software first
but a basic form is possible
in title designer zoom the image all the way in to where it fully covers the screen
then use the following animations
#3 Posted : Thursday, September 30, 2021 12:58:52 AM(UTC)
Correction
to use GT as stinger one needs a transition out too for best practice as the cut happens between end of transition in and beginning of transition out
fabfab10
#4 Posted : Thursday, September 30, 2021 1:01:26 AM(UTC)
fabfab10
Groups:: Registered
Italy
Thanks doggy for your replies.
The main question is : how do you zoom an image inside GT Designer?
I figured out all other transitions, just i couldn't manage to zoom the image
#5 Posted : Thursday, September 30, 2021 1:05:43 AM(UTC)
check the format tab or drag the corners of the image or move to the side and drag further etc
