GT
Custom Stinger for replay
Joined: 2/20/2019(UTC) Posts: 68  Location: Firenze Was thanked: 5 time(s) in 5 post(s)
Hello, i would like to create a custom stinger with a logo image with key to be used for replay transition like the one in the example below: Custom Stinger[YOUTUBE]https://youtu.be/SSYVEycV1Os?t=5229[/YOUTUBE] Using GT Designer i haven't found the way to zoom the image out as much as needed to cover the upcoming source (replay A or B). Any suggestion how to do this? Thank you in advance
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Preferably one woud create a image sequence with some other software first but a basic form is possible in title designer zoom the image all the way in to where it fully covers the screen then use the following animations  stinger.JPG (29kb) downloaded 3 time(s).
Correction to use GT as stinger one needs a transition out too for best practice as the cut happens between end of transition in and beginning of transition out  stinger2.JPG (31kb) downloaded 2 time(s).
Thanks doggy for your replies. The main question is : how do you zoom an image inside GT Designer? I figured out all other transitions, just i couldn't manage to zoom the image
check the format tab or drag the corners of the image or move to the side and drag further etc
GT
