	GT
	Custom Stinger for replay
 Joined: 2/20/2019(UTC) Posts: 68  Location: FirenzeWas thanked: 5 time(s) in 5 post(s)
                Hello, i would like to create a custom stinger with a logo image with key to be used for replay transition like the one in the example below:Custom Stinger [YOUTUBE]https://youtu.be/SSYVEycV1Os?t=5229[/YOUTUBE] Using GT Designer i haven't found the way to zoom the image out as much as needed to cover the upcoming source (replay A or B). Any suggestion how to do this? Thank you in advance |
 Joined: 12/27/2012(UTC) Posts: 5,449  Location: BelgiumThanks: 311 timesWas thanked: 1006 time(s) in 830 post(s)
                Preferably one woud create a image sequence with some other software first  but a basic form is possible  in title designer zoom the image all the way in to where it fully covers the screen  then use the following animations    stinger.JPG (29kb) downloaded 2 time(s). |
                Correction to use GT as stinger one needs a transition out too for best practice as the cut happens between end of transition in and beginning of transition out    stinger2.JPG (31kb) downloaded 1 time(s). |
                Thanks doggy for your replies.The main question is : how do you zoom an image inside GT Designer?
 I figured out all other transitions, just i couldn't manage to zoom the image
                check the format tab or drag the corners of the image or move to the side and drag further etc |
	GT
