Andrew Rix
#1 Posted : Saturday, September 18, 2021 12:26:07 AM(UTC)
Andrew Rix
I don't know if this has been covered before. I've searched but can't find anything.
Is it possible to make sure a sound file is at the beginning without loading it into the preview screen? If not a simple rewind button would be great!
mavik
#2 Posted : Saturday, September 18, 2021 12:35:34 AM(UTC)
mavik
You can set this in the options that it starts over every time it goes live.
Andrew Rix on 9/18/2021(UTC)
Andrew Rix
#3 Posted : Saturday, September 18, 2021 12:43:29 AM(UTC)
Andrew Rix
Thanks but I don't want to put it in either the preview or output screens. I just want to play it from the play button but need to make sure it's at the start
matkeane
#4 Posted : Saturday, September 18, 2021 1:27:13 AM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
If you're using hardware (midi, API) to play the audio file, you could use the 'Restart' shortcut in combination with the 'Play' shortcut to achieve this.
thanks 1 user thanked matkeane for this useful post.
Andrew Rix
#5 Posted : Saturday, September 18, 2021 2:26:03 AM(UTC)
Andrew Rix
Ah! Button down = Restart, button up = play.
Perfect! Thanks
