Feature Requests
Rewind button for sound files
Joined: 6/17/2020(UTC) Posts: 15  Location: Rugby Thanks: 11 times Was thanked: 1 time(s) in 1 post(s)
I don't know if this has been covered before. I've searched but can't find anything. Is it possible to make sure a sound file is at the beginning without loading it into the preview screen? If not a simple rewind button would be great!
You can set this in the options that it starts over every time it goes live.
 1 user thanked mavik for this useful post.
Thanks but I don't want to put it in either the preview or output screens. I just want to play it from the play button but need to make sure it's at the start
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
If you're using hardware (midi, API) to play the audio file, you could use the 'Restart' shortcut in combination with the 'Play' shortcut to achieve this.
 1 user thanked matkeane for this useful post.
Ah! Button down = Restart, button up = play. Perfect! Thanks
Feature Requests
