deankaru
#1 Posted : Monday, May 19, 2014 11:01:44 AM(UTC)
deankaru
Dear friends,
I have been testing out VMix and i find it very good. I have a small problem in setting up the output.
I have Bblackmagic SDI and also Blackmagic mini monitor installed,
I can create a capture input and all working fine, im having trouble in setting the output to minimonitor.
I managed to test the output on the Blackmagic SDI once before but since i cannot capture and use the output at the same time, i purchased Mini monitor after reading about it in this forum.
can somebody guide me towards the right way to set it up in Vmix 12.
im geting confused in external out setting and output.
My pc is i7, 32 gig memory running windows 7.
Thank you
#2 Posted : Monday, May 19, 2014 3:27:58 PM(UTC)
Was thanked: 506 time(s) in 475 post(s)
I'm not familiar with the BMD mini monitor, but I assume you have to set it up with the BMD control panel just like the Intensity Pro card (which is accessed through your computer's Control Panel)
http://www.streamingmedi...leID=83118&PageNum=2
Similar Topics
Help how to put vmix output NDI across segments (NDI)
by HULK622 11/27/2023 1:56:07 PM(UTC)
Vmix Output to Liveu Solo Help (Hardware Compatibility)
by wavystreams 11/26/2022 12:59:20 PM(UTC)
vMix output is zoomed in (General Discussion)
by loganyoon 2/1/2022 12:45:54 PM(UTC)
VMix Output 3 goes black/freezes (General Discussion)
by Plamen 10/31/2021 7:37:59 AM(UTC)
vMix output to OBS with transparency? (General Discussion)
by belboz 3/20/2021 2:33:56 PM(UTC)
vMix Output Monitoring to a Mobile Device (General Discussion)
by Rob009 2/17/2021 1:11:12 AM(UTC)
Recording vmix output from laptop (Systems)
by ArmandTanzarian 7/23/2020 1:41:42 PM(UTC)
Titles to Loop in vmix output (GT)
by bidyut 4/27/2020 9:18:26 PM(UTC)
VMIX output - encoder settings for the lowest SRT latency (SRT)
by pba 4/19/2020 9:47:27 AM(UTC)
Vmix output not showing up in skype for business (General Discussion)
by martin.zappe 4/9/2020 6:01:34 PM(UTC)
Audio shutter in vmix output (General Discussion)
by nitrox210 5/15/2019 5:24:51 AM(UTC)
Vmix output to UDP input (General Discussion)
by Franck 1/9/2019 7:25:02 AM(UTC)
vMix output as NDI on low bandwith network (NDI)
by wleuvering 3/13/2018 9:07:47 AM(UTC)
vMix Outputs (ovelays recording) (General Discussion)
by nilgarcia0 11/17/2017 2:04:54 PM(UTC)
vMix output on Android (vMix Call)
by slb5146 11/14/2017 11:45:41 PM(UTC)
vmix output visible on Lync, and Not Skype ... (General Discussion)
by toro2222 9/27/2017 9:14:59 AM(UTC)
Stream Camera Input Instead of vMix Output? (General Discussion)
by DC Mike 3/9/2017 5:09:22 AM(UTC)
usb type webcam vmix output (Feature Requests)
by h2video.nl 2/19/2017 7:53:39 AM(UTC)
Can't Capture Vmix Output (NDI)
by zakyrasyidi 10/1/2016 4:00:42 PM(UTC)
Stream feed is darker then vmix output. (General Discussion)
by thinkcustom 9/9/2016 4:29:30 PM(UTC)
Capture vMix output (Systems)
by Bckevin 10/20/2015 6:21:21 PM(UTC)
Vmix output (General Discussion)
by j1mco 4/3/2015 12:16:07 PM(UTC)
Video and Audio sync getting off by 2 seconds in 3-4 minutes time (when recording vmix output) (General Discussion)
by tdurhamjr 12/19/2014 11:29:22 PM(UTC)
Suggestions for Recording Vmix Output on external device (running on laptop) (General Discussion)
by tdurhamjr 12/6/2014 10:49:19 AM(UTC)
Media Foundation support for vMix Output (Feature Requests)
by MusicMan3001 2/21/2014 4:21:27 PM(UTC)
Send vMix output to FMLE running on separate computer (General Discussion)
by mat.murdock 1/17/2014 12:48:09 AM(UTC)
Sending Vmix output over Skype (General Discussion)
by h2video.nl 11/30/2012 4:40:41 AM(UTC)
