NDI
Help how to put vmix output NDI across segments
Help how to put vmix output NDI across segments I use A and B computers on different network segments. Using NDI Access Manager, I can transfer across network segments through NDI text patterns& screen capture. But how do I use the NDI output from vmix for cross-segment transmission?
You can use same NDI access manager or if this is over WAN tere is te Bridge app. Bridge requires an open port on the listening side
NDI
