HULK622
#1 Posted : Monday, November 27, 2023 1:56:07 PM(UTC)
HULK622
China
Help how to put vmix output NDI across segments
I use A and B computers on different network segments. Using NDI Access Manager, I can transfer across network segments through NDI text patterns& screen capture. But how do I use the NDI output from vmix for cross-segment transmission?
mavik
#2 Posted : Monday, November 27, 2023 11:51:32 PM(UTC)
mavik
You can use same NDI access manager or if this is over WAN tere is te Bridge app. Bridge requires an open port on the listening side
